Aggiornamento: X-7Zip
Vai a pagina   <<
rbon
dom 19 giu 2022 - 19:00
Utente registrato #4134
X-7-Zip 22.00
Link winPenPack
Aggiornamento dalla versione 21.07 alla 22.00
Home: -Link-
Sourceforge download page: -Link-
Direct Link: (32-bit): (non portatile) -Link-
Direct Link: (64-bit): (non portatile) -Link-
Changerlog
• 7-Zip now can extract APFS (Apple File System) images that can be used in DMG files.
• 7-Zip now can create TAR archives in POSIX (pax) tar format with the switches -ttar -mm=pax or -ttar -mm=posix
• 7-Zip now can store additional file timestamps with high precision (1 ns in Linux) in tar/pax archives with the following switches:
-ttar -mm=pax -mtp=3 -mtc -mta
• New switches for Linux version for TAR archives:
-snoi : store owner/group ids in archive or set owner/group ids from archive to extracted files.
-snon : store owner/group names in archive
• New -snz switch to propagate Zone.Identifier stream to extracted files (Windows).
• New option "Propagate Zone.Id stream" in Tools/Options/7-Zip menu.
• New "Options" window in "Add to archive" allows to select what metadata must be included to archive. Also it allows to select new option
"Do not change source files last access time".
• Some bugs were fixed.
ven 22 lug 2022 - 12:53
Utente registrato #9
Provenienza: Veglie
X-7-Zip 22.01
Link winPenPack
Aggiornamento dalla versione 22.00 alla 22.01
Home: -Link-
Changerlog
- UDF support was improved to UDF version 2.60.
- HFS and APFS support was improved.
[ Modificato ven 22 lug 2022 - 12:54 ]
mer 28 giu 2023 - 19:34
Provenienza: Veglie
X-7-Zip 23.01
Link winPenPack
Aggiornamento dalla versione 22.01 alla 23.01
Home: -Link-
Changerlog
- The page "Language" in 7-Zip's menu Tools/Options now shows information
about selected translation, including the number of translated lines.
- Some bugs were fixed
- 7-Zip now can use new ARM64 filter for compression to 7z and xz archives.
ARM64 filter can increase compression ratio for data containing executable
files compiled for ARM64 (AArch64) architecture.
Also 7-Zip now parses executable files (that have exe and dll filename extensions)
before compressing, and it selects appropriate filter for each parsed file:
- BCJ or BCJ2 filter for x86 executable files,
- ARM64 filter for ARM64 executable files.
Previous versions by default used x86 filter BCJ or BCJ2 for all exe/dll files.
- Default section size for BCJ2 filter was changed from 64 MiB to 240 MiB.
It can increase compression ratio for executable files larger than 64 MiB.
- UDF: support was improved.
- cpio: support for hard links.
- Some changes and optimizations in WIM creation code.
- When new 7-Zip creates multivolume archive, 7-Zip keeps in open state
only volumes that still can be changed. Previous versions kept all volumes
in open state until the end of the archive creation.
- 7-Zip for Linux and macOS now can reduce the number of simultaneously open files,
when 7-Zip opens, extracts or creates multivolume archive. It allows to avoid
the failures for cases with big number of volumes, bacause there is a limitation
for number of open files allowed for a single program in Linux and macOS.
- There are optimizations in code for 7-Zip's context menu in Explorer:
the speed of preparing of the menu showing was improved for cases when big number of
files were selected by external program for context menu that contains 7-Zip menu commands.
- There are changes in code for the drag-and-drop operations to and from 7-Zip File Manager.
And the drag-and-drop operation with right button of mouse now is supported for some cases.
- The bugs were fixed:
- ZIP archives: if multithreaded zip compression was performed with more than one
file to stdout stream (-so switch), 7-zip didn't write "data descriptor" for some files.
- ext4 archives: 7-Zip couldn't correctly extract symbolic link to directory from ext4 archives.
- HFS and APFS archives: 7-Zip incorrectly decoded uncompressed blocks (64 KiB) in compressed forks.
- Some another bugs were fixed.
[ Modificato mer 28 giu 2023 - 19:36 ]
gio 16 mag 2024 - 21:10
Provenienza: Veglie
X-7-Zip 24.05
Link winPenPack
Aggiornamento dalla versione 23.01 alla 24.05
Home: -Link-
Changelog
New switch -myv={MMNN} to set decoder compatibility version for 7z archive creating.
{MMNN} is 4-digit number that represents the version of 7-Zip without a dot.
If -myv={MMNN} switch is specified, 7-Zip will only use compression methods that can be decoded by the specified version {MMNN} of 7-Zip and newer versions.
If -myv={MMNN} switch is not specified, -myv=2300 is used, and 7-Zip will only use compression methods that can be decoded by 7-Zip 23.00 and newer versions.
New switch -myfa={FilterID} to allow 7-Zip to use the specified filter method for 7z archive creating.
New switch -myfd={FilterID} to disallow 7-Zip to use the specified filter method for 7z archive creating.
New menu item in 7-Zip File Manager: "Tools / Delete Temporary Files...".
This menu item opens a window showing temporary folders and files
created by 7-Zip in the user's "Temp" folder on a Windows system.
In this window, the user can delete temporary files.
7-Zip now can use new RISCV filter for compression to 7z and xz archives.
RISCV filter can increase compression ratio for data containing executable files compiled for RISC-V architecture.
The speed for LZMA and LZMA2 decompression in ARM64 version for Windows was increased by 20%-60%.
7-Zip GUI and 7-Zip File Manager can ask user permission to unpack RAR archives that require big amount of memory, if the dictionary size in RAR archive is larger than 4 GB.
new switch -smemx{size}g : to set allowed memory usage limit for RAR archive unpacking.
RAR archives can use dictionary up 64 GB. Default allowed limit for RAR unpacking is 4 GB.
7zg.exe (7-Zip GUI): -y switch disables user requests and messages.
7-Zip shows hash methods XXH64 and BLAKE2sp in context menu.
-slmu switch : to show timestamps as UTC instead of LOCAL TIME.
-slsl switch : in console 7-Zip for Windows : to show file paths with
linux path separator slash '/' instead of backslash separator '\'.
7-Zip supports .sha256 files that use backslash path separator '\'.
7-Zip now can unpack ZSTD archives (.zst filename extension).
7-Zip now can unpack ZIP, SquashFS and RPM archives that use ZSTD compression method.
7-Zip now supports fast hash algorithm XXH64 that is used in ZSTD.
7-Zip now can unpack RAR archives (that use larger than 4 GB dictionary) created by new WinRAR 7.00.
7-Zip now can unpack DMG archives that use XZ (ULMO/LZMA) compression method.
7-zip now can unpack NTFS images with cluster size larger than 64 KB.
7-zip now can unpack MBR and GDP images with 4 KB sectors.
Speed optimizations for archive unpacking: rar, cab, wim, zip, gz.
Speed optimizations for hash caclulation: CRC-32, CRC-64, Blake2sp.
The bug was fixed: 7-Zip for Linux could fail for multivolume creation in some cases.
[ Modificato gio 16 mag 2024 - 21:10 ]
lun 27 mag 2024 - 11:54
Provenienza: Veglie
X-7-Zip 24.06
Link winPenPack
Aggiornamento dalla versione 24.05 alla 24.06
Home: -Link-
Changelog
The bug was fixed: 7-Zip could not unpack some ZSTD archives.
[ Modificato gio 20 giu 2024 - 13:18 ]
gio 20 giu 2024 - 13:17
Provenienza: Veglie
X-7-Zip 24.07
Link winPenPack
Aggiornamento dalla versione 24.06 alla 24.07
Home: -Link-
Changelog
The bug was fixed: 7-Zip could crash for some incorrect ZSTD archives.
mer 14 ago 2024 - 08:33
Provenienza: Veglie
X-7-Zip 24.08
Link winPenPack
Aggiornamento dalla versione 24.07 alla 24.08
Home: -Link-
Changelog
- The bug in 7-Zip 24.00-24.07 was fixed:
For creating a zip archive: 7-Zip could write extra zero bytes after the end of the archive, if a file included to archive cannot be compressed to a size smaller than original.
The created zip archive is correct except for the useless zero bytes after the end of the archive.
When unpacking such a zip archive, 7-Zip displays a warning:
"WARNING: There are data after the end of archive". - The bug was fixed: there was a leak of GDI objects (internal resources in Windows) in "Confirm File Replace" window, causing problems after 1600 displays of "Confirm File Replace" window from same running 7-Zip process.
- Some optimizations for displaying file icons in 7-Zip File Manager and in "Confirm File Replace" window. -
- Some bugs were fixed.
sab 30 nov 2024 - 22:24
Provenienza: Veglie
X-7-Zip 24.09
Link winPenPack
Aggiornamento dalla versione 24.08 alla 24.09
Home: -Link-
Changelog
Spoiler:
[ Modificato sab 30 nov 2024 - 22:24 ]
lun 07 lug 2025 - 07:02
Provenienza: Veglie
X-7-Zip 25.00
Link winPenPack
Aggiornamento dalla versione 24.09 alla 25.00
Home: -Link-
Changelog
Spoiler:
[ Modificato lun 07 lug 2025 - 07:04 ]
Vai a pagina   <<
