valentino.b |
![]() ![]() Utente registrato #41787 Registrato il: gio 10 lug 2014 - 14:23Messaggi: 68 | Hi all exists a "portable tool" that allow us to create and run Virtual machines? I read that VirtualBox isn't usable ![]() Thank you | ||
eagleman |
![]() ![]() Utente registrato #9 Registrato il: sab 20 gen 2007 - 21:36Provenienza: Veglie Messaggi: 2119 ![]() | valentino.b ha scritto ... Hi all exists a "portable tool" that allow us to create and run Virtual machines? I read that VirtualBox isn't usable ![]() Thank you Many years ago I used to translate this software, MobaliveCD. Is not portable, but it's a stand-alone program that works as a virtual machine for Live-CD. With this program you can test a live OS before a final installation (usually Linux OS live CD). In any case, I'll try to find a more suitable program for you. | ||
valentino.b |
![]() ![]() Utente registrato #41787 Registrato il: gio 10 lug 2014 - 14:23Messaggi: 68 | I found GreenVBOX (http://greenvbox.org/) that can execute v.6.1.34 (lastest) of VirtuaBox without installation. It seems a freeware that can execute VirtuaBox like a portable. It could become a product of WinPenPack? | ||
eagleman |
![]() ![]() Utente registrato #9 Registrato il: sab 20 gen 2007 - 21:36Provenienza: Veglie Messaggi: 2119 ![]() | valentino.b ha scritto ... I found GreenVBOX (http://greenvbox.org/) that can execute v.6.1.34 (lastest) of VirtuaBox without installation. It seems a freeware that can execute VirtuaBox like a portable. It could become a product of WinPenPack? I don't think so, because they prefer to include only opensource programs. Test it with Regshot. Obviously you have to take a shot before installing GreenVBOX and another one after the program installation. Maybe the staff can consider it despite the freeware license. [ Modificato sab 28 mag 2022 - 13:15 ] | ||
Blackcrack |
![]() ![]() ![]() Utente registrato #41707 Registrato il: sab 28 dic 2013 - 08:45Messaggi: 29 | qemu, is portable, download the zip-package for you're Architecture (x86 or x86_64) https://www.qemu.org/download/#windows i see only setupfiles ? bahh.. extract the setup in a folder, include subfolders, go in and start qemu with "/?" switch and read the Manual/Documentary/instructions.. you can guide the qemu with bachfiles or directly with switches... (qemu.exe --bla --bla --bla" qemu was in the past a linux-binary in a rpm and be made later as a windows-binarys too.. therewith know i am , to be normally in native, portable, without a "Copy and link programm (so a setup programm)" because this, can you unpack qemu and put it into a folder&usb-stick and should run.. best Blacky [ Modificato lun 30 mag 2022 - 11:23 ] | ||
