Aggiornamento: X-Thunderbird Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 2.0.0.16 Link winPenPack Ita Version Link winPenPack Eng Version Aggiornamento dalla versione 2.0.0.14 alla 2.0.0.16 Home: -Link- Direct Link: (not portable - Ita) -Link- Direct Link: (not portable - En) -Link- [ Edited Thu 31 Jul 2008 - 14:45 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 2.0.0.17 Link winPenPack Ita Version Link winPenPack Eng Version Aggiornamento dalla versione 2.0.0.16 alla 2.0.0.17 Home: -Link- Direct Link: (not portable - Ita) -Link- Direct Link: (not portable - En) -Link- [ Edited Mon 27 Oct 2008 - 15:03 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 2.0.0.18 Link winPenPack Ita Version Link winPenPack Eng Version Aggiornamento dalla versione 2.0.0.17 alla 2.0.0.18 Home: -Link- Direct Link: (not portable - Ita) -Link- Direct Link: (not portable - En) -Link- [ Edited Sun 23 Nov 2008 - 10:46 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 2.0.0.19 Link winPenPack Ita Version Link winPenPack Eng Version Aggiornamento dalla versione 2.0.0.18 alla 2.0.0.19 Home: -Link- Direct Link: (not portable - Ita) -Link- Direct Link: (not portable - En) -Link- [ Edited Fri 23 Jan 2009 - 22:20 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 2.0.0.21 Link winPenPack Ita Version Link winPenPack Eng Version Aggiornamento dalla versione 2.0.0.19 alla 2.0.0.21 Home: -Link- Direct Link: (not portable - Ita) -Link- Direct Link: (not portable - En) -Link- [ Edited Mon 22 Jun 2009 - 17:58 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 2.0.0.22 Link winPenPack Ita Version Link winPenPack Eng Version Aggiornamento dalla versione 2.0.0.19 alla 2.0.0.21 Home: -Link- Direct Link: (not portable - Ita) -Link- Direct Link: (not portable - En) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Tue 23 Jun 2009 - 14:25 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Thunderbird 2.0.0.23 Link winPenPack Ita Version Link winPenPack Eng Version Aggiornamento dalla versione 2.0.0.22 alla 2.0.0.23 Home: -Link- Direct Link: (not portable - Ita) -Link- Direct Link: (not portable - En) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 21 Aug 2009 - 15:16 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1707 | X-Thunderbird 3.0 (EDITED By taf) Link Winpenpack Ita Link Winpenpack Eng Aggiornamento dalla versione 2.0.0.23 alla 3.0 Home: -Link- Direct Link versione italiana (non portatile): -Link- Direct Link versione inglese (non portatile): -Link- EDIT By taf: Prima di rilasciare la versione ufficiale sarà meglio testare bene il programma! tra la 2.0.0.XX e la 3.0 ci sono differenze equiparabili al passaggio tra FF2 e FF3 [ Edited Wed 20 Jan 2010 - 23:00 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Taf wrote ... Prima di rilasciare la versione ufficiale sarà meglio testare bene il programma! tra la 2.0.0.XX e la 3.0 ci sono differenze equiparabili al passaggio tra FF2 e FF3 Qui c'è una pre-release -Link- Ovviamente il contributo da parte di tutti per testare la nuova versione è molto gradito! | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Io lo stavo testando "sul campo" da una settimana (mi ero fatto la mia X version, senza modificare nulla del file INI) Posso dire che da punto di vista operativo è affidabile. Mai avuto problemi di funzionamento del programma. Ho riscontrato solo qualche inghippo con alcune estensioni: quando si sposta la chiavetta con X-thunderbird su un altro PC al primo avvio, alcune particolari estensioni che uso, richiedono un riavvio del programma stesso per essere funzionali al 100% (praticamente si auto sistemano - sono sempre patches di compatibilità). Ma è un limite delle estensioni stesse, non di Thunderbird 3 - Lo stesso problema mi si presenta/va anche com la versione 2). Sarò più preciso su quali estensioni sono "scorbutiche" domani (ora devo andare... il lavoro chiama) | ||
