X-Launcher for Software Update Monitor (SUMo)Go to page >> |
| ak1969 |
![]() ![]() Registered Member #16312 Joined: Wed 14 Jan 2009 - 20:43Posts: 7 | Hello, if somebody is interested I wrote a launcher for a small program that I find very useful for keeping the software I have on the portable USB media up-to-date. Here it is: Software name: SUMo Direct Link to download: -Link- ![]() File size: 1500 Kb Author's name: (if present) KC Softwares Author's eMail: (if present) Author's Website: -Link- ![]() Description: SUMo, which stands for Software Update Monitor. Thanks to SUMo you'll be able to keep your PC up-to-date by using the most recent version of your favorite software ! Unlike build-in auto update features, SUMo tells you if updates are available before you need to use your software. Features * Automatic detection of installed software * Detects required updates / patchs for your software * Filter / authorize Beta versions (user setting) * Ignore list : only tracks software YOU want to track * More compatibility and less false positive than others Update Monitors (according to users feedback * Internationalization support. Portable tips how-to: use the provided x-launcer X-SUMo - extract the folder SUMo into X-SUMo\Bin (so as to have X-SUMo\Bin\SUMo) - run X-SUMo.exe Version: X-SUMo launcher 1.3.1 ini rev1 (tested with SUMo 2.4.1.67) License: SUMo is freeware (but not opensource) ak1969 [removed] [ Edited Thu 15 Jan 2009 - 13:28 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | As I have already said by e-mail, SUMo is not an open source program. Therefore is not possible to link a modified version (or a launcher) on winPenPack.com, neither it is possible to portabilize (modifiy) it without author's permission. I had to remove the launcher. Please, search the corresponding open source program, portabilize it and share it with winPenPack community. Thank you for your collaboration. [ Edited Thu 15 Jan 2009 - 13:39 ] | ||
| ak1969 |
![]() ![]() Registered Member #16312 Joined: Wed 14 Jan 2009 - 20:43Posts: 7 | I'm sorry about this I did not understand well your first email... I thought that posting a launcher without including the software itself was OK. | ||
| Kyle_Katarn |
![]() ![]() Registered Member #40651 Joined: Sun 19 Aug 2012 - 13:39Posts: 17 | SUMo now have a portable version that CAN be included in your package. Kyle - SUMo lead developper | ||
| dito |
![]() ![]() Registered Member #11533 Joined: Sat 31 May 2008 - 09:32Posts: 200 | Appupdater potrebbe essere una alternativa open source. Esiste una versione portabile creata in stile Portableapps; questo il link al download: -Link- ![]() Questo il link ad una discussione relativa alla portabilizzazione ospitata su Portablefreeware: -Link- ![]() Questa la pagina web su Surgeforge: -Link- ![]() Homepage: -Link- ![]() Winapp_manager è una seconda alternativa, sempre open source. Esiste una versione portabile; questo il link al download: -Link- ![]() Questa la pagina web su Surgeforge: -Link- ![]() Homepage: -Link- ![]() [ Edited Sun 19 Aug 2012 - 21:21 ] | ||
| Kyle_Katarn |
![]() ![]() Registered Member #40651 Joined: Sun 19 Aug 2012 - 13:39Posts: 17 | SUMo - 5.9.4 (Released 2019-06-26) ================================== -Link- ![]() wrote ... 0005495: [Bug] SUMo starting with incomplete status text line (Kyle_Katarn) 0004239: [Refactoring] SUMo shall filter "DTS Post Processing APO" (Kyle_Katarn) 0005530: [Bug] "IOBit Uninstaller Portable" incorrectly detected as "IOBit Uninstaller" (Kyle_Katarn) 0005248: [Bug] Malwarebytes Corporate wrong update channel (Kyle_Katarn) 0005546: [Refactoring] Refactor "Steam Installer" (Kyle_Katarn) 0005540: [Refactoring] Updated Italiant translation (Kyle_Katarn) | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 935 ![]() | b.t.w. there is a portable version of this freeware made by John T. Haller (Portableapps.com): 1. SUMo portable: -Link- ![]() 2. program version: 5.9.4.424 3. paf size: 2 MB 4. program installed: 6 MB Surely he (John T. Haller) got permission from the author to build a portable with paf installer. | ||
| Kyle_Katarn |
![]() ![]() Registered Member #40651 Joined: Sun 19 Aug 2012 - 13:39Posts: 17 | SUMo - 5.9.5 (Released 2019-07-30) ================================== -Link- ![]() wrote ... 0005603: [Bug] "Search [...]" popup menu item not available for translation (Kyle_Katarn) 0005588: [Refactoring] Consolidate / Rationalize Multi Commander reporting (Kyle_Katarn) 0005597: [Refactoring] "POIbase powered by:" to be renamed "POIbase" (Kyle_Katarn) 0005592: [Bug] "DMDE" product naming to be reworked (embedding version number) (Kyle_Katarn) 0005598: [Refactoring] "WebGear Ltd" company name rationalization (Kyle_Katarn) 0005591: [Refactoring] "cURL" company name rationalization (Kyle_Katarn) 0005564: [Refactoring] Product name starting by "installs " to be filtered out (Kyle_Katarn) 0005602: [Refactoring] Updated Hungarian translation (Kyle_Katarn) | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 935 ![]() | In my opinion You do not must update this discussion because winPenPack do not develop a portable version of SUMo. In effect someone has already posted this update on PortableApps. Please see inside: -> PortableApps.com -> Development -> Outdated Official Portable Applications: -Link- ![]() | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 935 ![]() | I have found on Softpedia Portable SUMo at this page: -Link- ![]() En effect if You browse on KC Softwares at Download page, You may find SUMo Portable (file sumo.zip) at this link -Link- ![]() | ||
