X-SeaMonkey Development and Test Go to page << |
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Ecco un aggiornamento di versione / Here You can find a version update (da/from 2.0.2 EN a/to 2.0.3 IT) -Link- L'unica modifica presente in questa release riguarda l'aggiornamento del programma con l'ultima versione disponibile (2.0.3) localizzata in italiano. X-Launcher non è stato modificato, a parte la data data ed il commento di revisione. / The only modification regards the program update with the last version (2.0.3) localized in Italian. No modifications in the x-launcher but date and revison comments. | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | ITA Ecco Qua! Un' altra release di test aggiornata con Seamonkey 2.0.4 Come nella precedente versione, è stata modificato solo il contenuto della cartella /bin/ e i dati di release all'interno del file "x-seamonkey.ini" DL ITA: -Link- Naturalmente ogni feedback sarà sicuramente gradito ENG: Here it is! Another test release updated with Seamonkey 2.0.4 As the previous one, the only modification is on /bin/ folder and release update inside "x-seamonkey.ini" file DL ENG: -Link- Any feedback will be really appreciated [ Edited Wed 31 Mar 2010 - 18:25 ] | ||
pir |
Registered Member #2110 Joined: Thu 01 Feb 2007 - 20:42Location: France Posts: 14 | Hi evryone, Sorry for my long absence (some health problem followed by a 'long' stay far from civilization and internet). I'm glad to see that the launcher is working properly. @Taf: no idea about gmail manager extension, it maybe uses some non standard (or advanced ?) interaction outside of firefox/Seamonkey profile. @ZioZione: after some thoughts concerning an include feature, it seems not straitforward with today x-launcher code (but doable I think). I agree it will not be a so used feature but can help some dev to more easily share their work on common piece of X-software (I think also for example to GTK configuration that are found in many applications). Anyhow, considering the impact on x-launcher code compared to the benefits it might not be a so good idea in the short-term. [ Edited Sun 25 Apr 2010 - 04:47 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | pir wrote ... ---------- edit Danix ----------------------------------------------------------------- >> File rimosso causa bug grave nel launcher: utilizzando questa versione di sviluppo viene eliminato irreversibilmente un eventuale profilo già esistente nel pc ospitante.<< ----------------------------------------------------------------------------------------------- Beta-release da rivedere -Link- | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Riporto qui un'aggiornamento dell'attuale situazione di SeaMonkey: Seamonkey-2.3.2 Aggiornamento dalla versione 2.3 alla 2.3.2 Home -Link- Direct link (ITA) (EXE non portatile) -Link- Direct link (ITA) (ZIP non portatile) -Link- Direct link (ENG) (EXE non portatile) -Link- Direct link (ENG) (ZIP non portatile) -Link- visto che ora il programma si è fatto piuttosto interessante e maturo come "all-in-one", forse si potrebbe riprovare a mettere in piedi un launcher dedicato [ Edited Thu 01 Sep 2011 - 16:40 ] | ||
Go to page <<
