X-SeaMonkey Development and Test
Go to page   <<
Fri 19 Mar 2010 - 19:06
Ecco un aggiornamento di versione / Here You can find a version update (da/from 2.0.2 EN a/to 2.0.3 IT)
L'unica modifica presente in questa release riguarda l'aggiornamento del programma con l'ultima versione disponibile (2.0.3) localizzata in italiano. X-Launcher non è stato modificato, a parte la data data ed il commento di revisione. / The only modification regards the program update with the last version (2.0.3) localized in Italian. No modifications in the x-launcher but date and revison comments.
Wed 31 Mar 2010 - 18:23
ITA
Ecco Qua!
Un' altra release di test aggiornata con Seamonkey 2.0.4
Come nella precedente versione, è stata modificato solo il contenuto della cartella /bin/ e i dati di release all'interno del file "x-seamonkey.ini"
DL ITA: -Link-
Naturalmente ogni feedback sarà sicuramente gradito
ENG:
Here it is!
Another test release updated with Seamonkey 2.0.4
As the previous one, the only modification is on /bin/ folder and release update inside "x-seamonkey.ini" file
DL ENG: -Link-
Any feedback will be really appreciated
[ Edited Wed 31 Mar 2010 - 18:25 ]
pir
Sun 25 Apr 2010 - 04:46
Registered Member #2110
Hi evryone,
Sorry for my long absence (some health problem followed by a 'long' stay far from civilization and internet). I'm glad to see that the launcher is working properly.
@Taf: no idea about gmail manager extension, it maybe uses some non standard (or advanced ?) interaction outside of firefox/Seamonkey profile.
@ZioZione: after some thoughts concerning an include feature, it seems not straitforward with today x-launcher code (but doable I think). I agree it will not be a so used feature but can help some dev to more easily share their work on common piece of X-software (I think also for example to GTK configuration that are found in many applications). Anyhow, considering the impact on x-launcher code compared to the benefits it might not be a so good idea in the short-term.
[ Edited Sun 25 Apr 2010 - 04:47 ]
Thu 21 Oct 2010 - 00:35
pir wrote ...
---------- edit Danix -----------------------------------------------------------------
>> File rimosso causa bug grave nel launcher: utilizzando questa versione di sviluppo
viene eliminato irreversibilmente un eventuale profilo già esistente nel pc ospitante.<<
Beta-release da rivedere -Link-
Thu 01 Sep 2011 - 16:38
Riporto qui un'aggiornamento dell'attuale situazione di SeaMonkey:
Seamonkey-2.3.2
Aggiornamento dalla versione 2.3 alla 2.3.2
Home -Link-
Direct link (ITA) (EXE non portatile) -Link-
Direct link (ITA) (ZIP non portatile) -Link-
Direct link (ENG) (EXE non portatile) -Link-
Direct link (ENG) (ZIP non portatile) -Link-
visto che ora il programma si è fatto piuttosto interessante e maturo come "all-in-one", forse si potrebbe riprovare a mettere in piedi un launcher dedicato
[ Edited Thu 01 Sep 2011 - 16:40 ]
Go to page   <<
