[winPenPack Net Menu] Swedish translationVai a pagina << |
| eson |
![]() ![]() ![]() Utente registrato #40310 Registrato il: mer 21 mar 2012 - 09:23Messaggi: 7 | Danix ha scritto ... P.S. Please note that there is only the translation of the list ("winpenpack_sv.xml") and not the "winPenPack.sv.ini" file. Hi Danix! May I ask why you did not add my "winPenPack.sv.ini" file? Is there something wrong with it? Works just fine on my machine. //eson [ Modificato sab 10 nov 2012 - 12:51 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | I'm sorry, eson, but I had not seen! I will update the package as soon as possible. In the meantime can you check that all strings are translated? I think in new files there is some change. -- edit -- Diff to previous -Link- ![]() [ Modificato sab 10 nov 2012 - 13:21 ] | ||
| eson |
![]() ![]() ![]() Utente registrato #40310 Registrato il: mer 21 mar 2012 - 09:23Messaggi: 7 | Ok... I found the one new string. Here´s the updated files attached. sv_winpenpacknetmenu_2867.zip[ Modificato sab 10 nov 2012 - 15:12 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | I have updated the package -Link- ![]() Thank you for the translation! -Link- ![]() | ||
Vai a pagina <<
