![]() Vai a pagina >> |
gibdemaffen |
![]() ![]() Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | Hi again, 3 things I'd really love to see are: 1) being able to set file associations for VLC media player, like it is e.g. for 7-zip 2) 7-zip should be able to integrate itself into the context menu (like the version of portableapps.com is able to) 3) please offer the latest beta versions (9.xx) instead or at least aside the "stable" version (4.xx), because the 9.xx versions are much faster and got great new features it would be great to see these changes coming up in the near future. ![]() | ||
![]() ![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | Hi gibdemaffen, about the third point there is a specific note for the compatibility of X-7Zip launcher with the Beta version here, but (I'm sorry ![]() Fast translation: the actual launcher works fine with the beta version, I've tested with the 9.13 release (not yet with new 9.14). Since now we didn't release X-7Zip beta 'cause it was not really stable, but the latest versions seems to work fine, so I think that is time to release the "X-7Zip Beta Version". Stay tuned! | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12977 ![]() | gibdemaffen ha scritto ... 1) being able to set file associations for VLC media player, like it is e.g. for 7-zip I think it's better to set portable file associations with X-Cafe -Link- ![]() gibdemaffen ha scritto ... 2) 7-zip should be able to integrate itself into the context menu (like the version of portableapps.com is able to) The portableapps version should be started, like X-AstroGrep -Link- ![]() [ Modificato lun 07 giu 2010 - 22:10 ] | ||
![]() ![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | As promised, brand new 7Zip 9.14 beta available in download -Link- ![]() Be careful, is still a beta!!! | ||
gibdemaffen |
![]() ![]() Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | thanks =) works great - no problems so far with this certain version. ![]() however there is one flaw that all portable versions of 7zip have in common: a problem with the context menu. as you see here I did not tick all options to be available in the context menu (http://img210.imageshack.us/i/080620101816053.png/) but still also the unticked options appear in the context menu (http://img405.imageshack.us/i/080620101816054.png/) is there a way to solve that problem coming from the portable point of view, or is this a flaw by nature of design (regarding the 7z.dll)? having to deal with other folder structures etc. or not using the wppmenu makes thing more difficult if you need to rely on x-cafe. being able to simply set associations via vlc itself would be much easier in most cases and make the WPP version of vlc so much better compared to any other portable version. [ Modificato mar 08 giu 2010 - 18:32 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12977 ![]() | Regarding the context menu option, please try the new X-7Zip 9.14 beta [rev7] release. | ||
gibdemaffen |
![]() ![]() Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | edit: sorry my bad. didn't read carefully enough. anyway: rev7 works like a charm!!! the context menu is now customizable just like it is on the installed version. you guys did an awesome job! ![]() ![]() ![]() ![]() ![]() ![]() ![]() thanks 1000 times - this stuff is perfect now. ![]() cheers ![]() [ Modificato mar 08 giu 2010 - 21:43 ] | ||
![]() ![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | @gibdemaffen, try this version: X-7Zip 9.14 beta [rev8]. The software is the same, but here I put the settings to activate automatically the context menu at the first run, without the need to select the specific option. To be honest, I don't like it at all, 'cause in this way you cannot deactivate the functionality (it will be reactivate at the next run). [ Modificato mar 08 giu 2010 - 23:34 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12977 ![]() | zandet2 ha scritto ... The software is the same, but here I put the settings to activate automatically the context menu at the first run, without the need to select the specific option. Sincerely, I had left the option expressly to the user's freedom.. ![]() Why block the option if everyone can decide whether to activate it or not? The result is the same. Among other things, both the rev_7 and the rev_8 have trouble with context menu if you move the program: ![]() I think because the 7-zip.dll is in use: ![]() I have tested in a Virtual Machine and I had not troubles moving the program.. I don't understand.. ![]() Test needed. zandet2, about the changes between the rev_ 7 and rev_8, I think it is sufficient to add only:
[WriteToReg=$Home$\$AppName$\$AppName$_3.reg]
In this way:
![]() P.S.: zandet2, probably it would have been better to leave the stable X-7Zip version in the download section and release in the "Beta releases" forum section these beta releases, that (as we have seen) must be well tested. As we have always done (at least lately) .. ![]() ![]() | ||
![]() ![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | Danix, you are right (as usual), but... since our users does not consider a lot (or at all) the "beta" section of the forum, to release this version of X-7Zip I prefer this way, following the example of X-GnuCash. | ||
