X-Tor 0.2.2.32 [rev10] incompatible with X-Firefox 3.6.20 [rev18] Vai a pagina << |
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Thank you for the offer of the package relating to the use of X-Tor in conjunction with X-Firefox 3. Now this version works fine. Danix wrote ... Maybe a problem in Polipo configuration. Is the field "Proxy Application Arguments" in "General" tab empty? Unfortunately I could not understand exactly, in which "General" tab I should look at an empty field named "Proxy Application Arguments". ZioZione wrote ... Otherwise, you can still user AdvOR -Link- and see if it fits your needs... Thank you for the advice for use of the AdvOR. Of course I will also look at this solution in detail. [ Modificato mar 06 set 2011 - 13:21 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | dropper ha scritto ... Unfortunately I could not understand exactly, in which "General" tab I should look at an empty field named "Proxy Application Arguments". Vidalia main panel >> Settings >> General >> "Proxy Application Arguments": Please, let me know if the field is empty, I would like to know why it doesn't work. Anyway, you could use directly the new package that I provided. [ Modificato mar 06 set 2011 - 15:30 ] | ||
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Oddly, it sometimes happens that I get an access to the Internet and then again not during the use of X-Tor in conjunction with X-Firefox 3. For access to the Internet I use a router. Maybe I should forward the ports in the router, which uses the proxy server Polipo? On the other hand, I have during the use of X-Tor in conjunction with X-Firefox 6 no problems. In this respect it seems the router does not be the cause for the lack of connection to the Internet.
[ Modificato mar 06 set 2011 - 17:54 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | I also have a router, but I have not configured any ports.
dropper |
[ Modificato mar 06 set 2011 - 18:19 ] | ||
Vai a pagina <<
