![]() Vai a pagina >> |
dropper |
![]() ![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | According to this tutorial I've tried to use X-Tor 0.2.2.32 [rev10] stand-alone. In conjunction with X-Firefox 3.6.20 [rev18] I get an error message that the browser can't be started (in the case of the use of X-Tor 0.2.1.30 [rev9] in conjunction with X-Firefox 3.6.20 [rev18] everything works fine). If I use X-Tor 0.2.2.32 [rev10] in conjunction with X-Firefox 6.0.1 [rev4], then it's possible to start Firefox. However, then the message "Tor enabled" is not displayed in the lower right corner of the browser's window. Therefore I can't surf anonymous in this case. | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | In order to use X-Tor 0.2.2.32 [rev10] in conjunction with X-Firefox 3.6.20 [rev18] you have just to modify X-Firefox.ini at line 64 from:
;(X-Firefox integration)
to:
I think it is enough, but I don't know if Torbutton v1.4.2 (included in the last X-Tor release) is compatible with Firefox 3. If not, copy the {e0204bd5-9d31-402b-a99d-a6aa8ffebdca} folder from attached ![]() [ Modificato lun 05 set 2011 - 21:08 ] | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Hi dropper, dropper ha scritto ... According to this tutorial I've tried to use X-Tor 0.2.2.32 [rev10] stand-alone. In conjunction with X-Firefox 3.6.20 [rev18] I get an error message that the browser can't be started (in the case of the use of X-Tor 0.2.1.30 [rev9] in conjunction with X-Firefox 3.6.20 [rev18] everything works fine). If I use X-Tor 0.2.2.32 [rev10] in conjunction with X-Firefox 6.0.1 [rev4], then it's possible to start Firefox. However, then the message "Tor enabled" is not displayed in the lower right corner of the browser's window. Therefore I can't surf anonymous in this case. as Danix said, this is the opposite problem you had here -Link- ![]() But this requires that X-Tor must be adapted to one of the X-Firefox versions (as depicted above by Danix). Probably (we have to decide it), due to the actual incompatibility of Torbutton and Firefox 6, X-Tor will be released only in a version compatible with X-Firefox-3. But in the future this problem may arise again, so is better to search in the forum for these two possible solutions... ![]() Best Regards ZioZione | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | ZioZione ha scritto ... Probably (we have to decide it), due to the actual incompatibility of Torbutton and Firefox 6, X-Tor will be released only in a version compatible with X-Firefox-3. Torbutton is compatible with Firefox 6! ![]() Or at least it seems (test NEEDED ![]() I have released today X-Tor 0.2.2.32 [rev10] to use in conjunction with X-Firefox 6.0.1. [ Modificato lun 05 set 2011 - 21:17 ] | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Hi Danix, Danix ha scritto ... ZioZione ha scritto ... Probably (we have to decide it), due to the actual incompatibility of Torbutton and Firefox 6, X-Tor will be released only in a version compatible with X-Firefox-3. Torbutton is compatible with Firefox 6! ![]() ![]() Best Regards ZioZione | ||
dropper |
[ Modificato lun 05 set 2011 - 21:42 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | dropper ha scritto ... Use of X-Tor 0.2.2.32 [rev10] in conjunction with X-Firefox 3.6.20 [rev18] As described by Danix, I modify X-Tor.ini at line 64. But in this case it's impossible to download Firefox. Instead I get an error message (error: 3). Please try X-Firefox-3 3.6.21 [rev18]. | ||
dropper |
![]() ![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | I've try X-Firefox 3.6.21 [rev18] and actually it's now possible to download Firefox. Danix wrote ... I think it is enough, but I don't know if Torbutton v1.4.2 (included in the last X-Tor release) is compatible with Firefox 3. If not, copy the {e0204bd5-9d31-402b-a99d-a6aa8ffebdca} folder from attached torbutton.zip into \User\Firefox-3\Profiles\Default\extensions. Because the Torbutton v1.4.2 (included in the last X-Tor release) is not compatible with Firefox 3, I copy the folder {e0204bd5-9d31-402b-a99d-a6aa8ffebdca} into \User\Firefox 3\Profiles\default\extensions. Unfortunately, I now constantly get the following error message: Proxy-Server is refusing the connection. [ Modificato lun 05 set 2011 - 23:07 ] | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Hi dropper, maybe here -Link- ![]() Otherwise, you can still user AdvOR -Link- ![]() ![]() Best Regards ZioZione | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | dropper ha scritto ... Unfortunately, I now constantly get the following error message: Proxy-Server is refusing the connection. Maybe a problem in Polipo configuration. Is the field "Proxy Application Arguments" in "General" tab empty? However, try the below package I've created with X-Tor latest version to use in conjunction with X-Firefox 3. I have no problem with this: ![]() [ Modificato dom 02 ott 2011 - 01:42 ] | ||
