annoying dialog window at every start of X-Thunderbird
dropper
mer 17 lug 2013 - 22:59
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
At every start of X-Thunderbird a dialog window named "System Integration" will opened. In this window will me offered the option, that I can choose Thunderbird as the default email program on my PC. Accordingly must I click on the button "Cancel" everytime. That's not really convinient I use the OS Windows 8.
[ Modificato mer 17 lug 2013 - 23:01 ]
mer 17 lug 2013 - 23:10
As usual (I hope),x-thunderbird.ini file can be your friend!
have a look if under [USER PREFERENCES]
you have this line:
; Default Client
mail.shell.checkDefaultClient=false
if you already have this option (not commented), maybe we need to test X-thunderbird on Win8 system.
dropper
mer 17 lug 2013 - 23:20
In the file X-Thunderbird.ini under [USER PREFERENCES] I found exactly the line, which you've mentioned in your comment. Accordingly is there an issue with the OS Windows 8.
gio 18 lug 2013 - 09:29
OK, now the biggest problem is to find out a Windows 8 PC in our staff!
