X-Lazarus_0.9.30.4_rev5 Error. Thanks. |
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | I test on windows xp and win 7(64bit) both has same problems. when i try created the new application and press F9, try to complier show me and error C:\X-Lazarus 0.9.30.4rev5\Bin\Lazarus\lcl\masks.pas(29,22) Fatal: Can't find unit contnrs used by Masks I try to use default setting or try to fix, but can't be slove. hope help and fix, | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | Hi dlusera, I suggest You to try another build of Lararus Portable: - author: Zack Hawkins - Sougeforge page of author: -Link- - Sourceforge project page: -Link- - Lararus Portable ver 0.9.30.4: -Link- - Lararus Portable Development Test nr. 2 (Update at April 25, 2012) direct download: -Link- - Softpedia: -Link- If this build work properly, You can suggest to winPenPack Team some corrections to Lazarus Launcher. [ Edited Mon 03 Sep 2012 - 16:36 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Hi dlusera, sorry for the late reply, but it was really hard for me (I do not use Lazarus) to find a solution. The problem is caused by a missing configuration file in the fpc directory, not present even in the original package. If you can help us, please download the attached zip, and in a clear version of X-Lazarus substitute the original X-Lazarus.exe and X-Lazarus.ini with the files in the zip below: x-lazarus_test.zip If the test is ok, we can distribute the complete version. Thank you. | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | Sorry, longer reply, this testing version is working now. just a loading speed is litter slow, compare with old version . may be set too many path. any how, thanks again. | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Hi dlusera, glad to see your reply we will use the new launcher with the next release of X-Lazarus. Thanks for your test! | ||
