Modifiche e aggiornamenti software da winPenPack 3.1 Go to page << >> |
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: WinAudit 2.24 Win PE/95/98/Me/NT3.51/NT4/2000/XP/2003/Vista Link winPenPack Aggiornamento dalla versione 2.23 alla 2.24 Home: -Link- Direct Link: -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: X-Pidgin 2.1.1 Winpenpack link Aggiornamento dalla versione 2.1.0 alla 2.1.1 Home: -Link- Direct Link: -Link- (not portable) [ Edited Tue 21 Aug 2007 - 23:32 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-FileZilla [rev8] -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update: X-AstroGrep 4.1.3 Windows 9x/2000/XP/Vista -Link- [ Edited Wed 22 Aug 2007 - 02:13 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update INI: X-Mule [rev6] -Link- | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: X-Foxit Reader 2.1 build 2023 Link WinPenPack Aggiornamento dalla versione 2.0 alla 2.1 Build 2023 Home: -Link- Direct LinK: -Link- [ Edited Thu 23 Aug 2007 - 19:52 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Update: X-Solfege 3.8.2 Link WinPenPack Aggiornamento dalla versione 3.8.1 alla 3.8.2 Home: -Link- Direct Link: -Link- [ Edited Thu 23 Aug 2007 - 20:49 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: X-ClamWin 0.91.2 Link winPenPack Aggiornamento dalla versione 0.91.1 alla 0.91.2 Home: -Link- Direct Link: (not portable) -Link- [ Edited Fri 24 Aug 2007 - 15:42 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: X-Orbit Downloader 2.1.7 Link winPenPack aggiornamento dalla versione 2.1.6 alla versione 2.1.7 Home: -Link- Direct Link: (not portable) -Link- [ Edited Fri 24 Aug 2007 - 15:42 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Change: X-vDC++ verrà sostituito con X-iDC++ -Link- [ Edited Sat 25 Aug 2007 - 03:41 ] | ||
