Aggiornamento: X-ChromiumVai a pagina << >> |
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi there! the newest version of chromium 6.0.426.0 (49004) -Link- ![]() works without problem with x-launcher. news for this version is the support for WebM - new HTML5 video codec with V8 and vorbis audio codec inside. for some reason I could not activate build in flash player - the solution for that is : find flashplayer.xpi downlowed and change extention to .zip extract flashplayer.xpt and NPSWF32.dll create folder "plugins" in \X-Chromium_6.0.397.0_build46552_rev10\Bin\Chrome and copy extracted files there and you can enjoy with portable browser with portable flashplayer now :] Ciao a tutti J =============== New topic -Link- ![]() =============== [ Modificato dom 20 giu 2010 - 12:12 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | We are off topic.. This topic (normally) must be used for updates signallings. From now, for questions concerning the development or for ANY OTHER QUESTION other than updates, please open a new topic! In order to facilitate the search in website, should be opened a topic for each question. | ||
| gibdemaffen |
![]() ![]() Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | --snip-- sorry didn't read this topic is only for updates. i'll open a new thread. (here: -Link- ![]() [ Modificato mer 29 set 2010 - 07:19 ] | ||
| zandet2 |
![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | X-Chromium 9.0.584.0 build 66139 Link winPenPack Aggiornamento dalla versione 6.0.397.0 build 46552 alla versione 6.0.398.0 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Modificato lun 15 nov 2010 - 23:39 ] | ||
| phant0mw0rm |
![]() ![]() Utente registrato #5039 Registrato il: mer 06 giu 2007 - 12:08Messaggi: 73 | X-Chromium 11.0.666.0 Link alla pagina download winPenPack Aggiornamento dalla versione 9.0.584.0 build 66139 alla versione 11.0.666.0 build 74274 Home Direct Link: (not portable) | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Il link all'ultima versione non è più disponibile -Link- ![]() Qualcuno riesce a trovare il server da cui scaricare l'ultima versione? | ||
| Rcs |
![]() ![]() ![]() ![]() Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 ![]() | -Link- ![]() | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Mi da versione 16.0.877.0 (Build 100430 Windows), sarà mica il caso di aggiornare? | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | X-Chromium 16.0.877.0 (Build 100430 Windows) Link winPenPack Aggiornamento dalla versione 12.0.715.0 alla versione 16.0.877.0 (Build 100430) Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Per provare a risolvere questo bug -Link- forse si potrebbe aggiornare. Ma continua a non essere disponibile.. ============== edit =============== forse qui c'è l'ultima -Link- ![]() ===================================== [ Modificato gio 29 set 2011 - 16:19 ] | ||
