Aggiornamento: X-Chromium
Go to page   <<        >>
JackL
Sat 05 Jun 2010 - 12:48
Registered Member #6127
Hi there!
the newest version of chromium 6.0.426.0 (49004)
works without problem with x-launcher.
news for this version is the support for WebM - new HTML5 video codec with V8 and vorbis audio codec inside.
for some reason I could not activate build in flash player - the solution for that is :
find flashplayer.xpi
downlowed and change extention to .zip
extract flashplayer.xpt and NPSWF32.dll
create folder "plugins" in \X-Chromium_6.0.397.0_build46552_rev10\Bin\Chrome
and copy extracted files there
and you can enjoy with portable browser with portable flashplayer now :]
Ciao a tutti
J
New topic -Link-
[ Edited Sun 20 Jun 2010 - 12:12 ]
Sun 20 Jun 2010 - 12:13
We are off topic..
This topic (normally) must be used for updates signallings.
From now, for questions concerning the development or for ANY OTHER QUESTION other than updates, please open a new topic!
In order to facilitate the search in website, should be opened a topic for each question.
gibdemaffen
Wed 29 Sep 2010 - 07:16
Registered Member #38871
--snip--
sorry didn't read this topic is only for updates. i'll open a new thread. (here: -Link-
[ Edited Wed 29 Sep 2010 - 07:19 ]
Mon 15 Nov 2010 - 23:25
X-Chromium 9.0.584.0 build 66139
Link winPenPack
Aggiornamento dalla versione 6.0.397.0 build 46552 alla versione 6.0.398.0
Home: -Link-
--- edit zandet2 ---
software wpp aggiornato
[ Edited Mon 15 Nov 2010 - 23:39 ]
phant0mw0rm
Wed 09 Feb 2011 - 15:21
Registered Member #5039
X-Chromium 11.0.666.0
Link alla pagina download winPenPack
Aggiornamento dalla versione 9.0.584.0 build 66139 alla versione 11.0.666.0 build 74274
Home
Direct Link: (not portable)
Mon 12 Sep 2011 - 14:41
Il link all'ultima versione non è più disponibile -Link-
Qualcuno riesce a trovare il server da cui scaricare l'ultima versione?
Mon 12 Sep 2011 - 15:05
Registered Member #675
Mon 12 Sep 2011 - 15:23
Mi da versione 16.0.877.0 (Build 100430 Windows), sarà mica il caso di aggiornare?
Mon 12 Sep 2011 - 17:04
X-Chromium 16.0.877.0 (Build 100430 Windows)
Link winPenPack
Aggiornamento dalla versione 12.0.715.0 alla versione 16.0.877.0 (Build 100430)
Home: -Link-
Thu 29 Sep 2011 - 16:16
Rcs wrote ...
Per provare a risolvere questo bug -Link- forse si potrebbe aggiornare. Ma continua a non essere disponibile..
============== edit ===============
forse qui c'è l'ultima -Link-
[ Edited Thu 29 Sep 2011 - 16:19 ]
Go to page   <<        >>
